Mesh from a Point cloud
Hello Community,
I am using Rhino 6 to create a Mesh from a point cloud. When i use the comand mesh from points. The mesh is made from boxes,
but i want it to be fluent. how can i fix it. Or is there a better way to create an object from a point cloud in rhino.
Thank you
Try MeshPatch perhaps… If you have a lot of points it may take awhile.
its 1.2 mio points… do you think it might work? and do you maybe know why it creates these boxes instead of a normal surface?
Possibly. Save everything first in case Rhino runs out of memory…
I don’t know how MeshFromPoints works actually… never used it.
ok thanks! ive read something about a solution with grasshoper and the delaunay function does it also work for a point cloud with million points?
I remember they basically share the same algorithm. So I’d use Rhino’s MeshPatch to avoid Grasshopper overhead (in data type processing).
The project I am working on has a terrain of 1M points. MeshPatch creates the mesh in about 3 seconds. But MeshPatch is best for seemingly-smooth surface.
When i use normal patch this happens:
And how do you use mesh patch? i dont get it cause it asks for a surface to drag the points … im confused
thanks
There’s a command called MeshPatch. Patch is for NURBS surface.
and how do you use mesh patch, cause when i selec my points it asks for holes and surfaces??
never mind just press enter… but i still get the boxes…
If you get the boxes with MeshPatch, then that’s the way your points are organized it seems…
That’s weird. :thinking: Don’t quite know why.
i mean its a normal point cloud i would say with normal points
It worked with delaunay in grasshoper
Odd - MeshPatch should use more or less the same method. Is there any way someone can download the points file to test?
