Hi All,
how can I access the coordinates of Mesh Face centroids in Grasshopper Scripting?
I only found the Mesh.FaceNormals.ComputeFaceNormals method, but it returns a boolean - which doesn’t help me that much.
Basically, I’m looking for an equivalent rhino.MeshFaceCenters(strMesh) method from rhinoscript for Grasshopper scripting.
Thanks a lot for any help!
Chris
Hi @Christoph1,
for a single mesh face you can use:
mesh.Faces.GetFaceCenter(index)
where index
is the number of the mesh face. To get all centers in one go, you could use something like this:
import Rhino
def MeshFaceCenters():
id = rs.GetObject("select mesh", 32, True, False)
if not id: return
mesh = rs.coercemesh(id)
centers = [mesh.Faces.GetFaceCenter(i) for i in xrange(mesh.Faces.Count)]
rs.AddPoints(centers)
if __name__=="__main__":
MeshFaceCenters()
Here is more info about GetFaceCenters()
method.
c.
Thanks! That helped!
…and mesh.FaceNormals.item(index) gives me the normals.
I just realized, that the auto-completion in the script-components of Grasshopper is not complete. So, e.g. it didn’t show me the .item list. So I should rather look up class functions here: http://4.rhino3d.com/5/rhinocommon/
Cheers Chris
