Mesh Division
Hello
is
there any command or plugin that makes objects made with nurbs in a
mesh with square polygons to be easier to map with 3ds max?
thank you
If you’re using Rhino v6 Try the Quadmesh command
I think the QuadMesh command is only available in the (V7) WIP…
Maybe i should’ve mentioned that i was talking about Rhino V6 WIP.
Maybe it was removed from the final release, because i’m using it.
Yes, it was. It is in the in the current (V7) WIP though.
