Mesh curvature Pythonscript code to .net
I have a Pythonscript file , here is the code.
def CurvaM0(topvertex,connection):
    type=Rhino.Geometry.Point3d
    Kmax=[]
    Kmin=[]
    t=0
    for i in connection:
        points=[]
        for j in i:
            points.append(topvertex[j])
        pts=Converts(points,type)
        pt=Convert(topvertex[t],type)
        ind=topvertex.MeshVertexIndices(t)
        nn=mesh.Normals[ind[0]]
        nor=Rhino.Geometry.Point3d(nn.X+pt.X, nn.Y+pt.Y, nn.Z+pt.Z)
        K=Curvature0(pts,pt,nor)
        K.sort()
        Kmax.append(K[1])
        Kmin.append(K[0])
        t=t+1
    return Kmax,Kmin
 topvertex  ---- MeshTopologyVertexList
 connection ---- List(Of List(Of Integer))
 nn              ---- Vector3d
 nor             ---- Point3d
 pt               ---- Point3d
The result calculated based on the pythonscript code below is weird .
when I pass data into the code, for instance,
nn.X+pt.X= -0.9816897-35.1987609863281=-36.1804506778717
nn.Y+pt.Y= -0.0908464226052352-16.2358417510986=-16.2305486575
nn.Z+pt.Z= 0.995861129123327+0.114346027374268=0.304759517312
but the result of nor based on the pythonscript actually is
nor.x=-0.00273924704027273
nor.y=-0.0908464226052352
nor.z=0.995861129123327
I’m confused about the results, any advice?
BR
Kalvin
Can you please share the file (not just the function) and a sample if possible, so we can run at our end?
Hi,Rajaa
I’ve solved it ,the reaseon is I used the wrong variable scope.
Thank you for you help.
BG
Kalvin
