Hello
Recently I have added the plugin called “GEODESIC HEAT METHOD” and It doesn’t work particularly in one of my laptop. I’m getting the error “Mesh creation failed” whenever I tried to use the component from the plugin. But the plugin works fine with other computers. I don’t think the problem is with the plugin, because with the same file is working in different laptops.
I have even uninstalled and reinstalled the Rhino to find the solution, but that doesn’t help.
Note: I have unblocked all the files before placing them in component folder.
