Mesh CreateFromCurveExtrusion bug
Given a flat closed curve, I want to extrude it in the upwards z direction. Given the dimensions of the boundingbox, I would expect the curve to extrude only in the positive z direction. However, the rg.Mesh.CreateFromCurveExtrusion seems to extrude in the negative direction as well (negative z extrusion distance always seems to be -1, even if I change my vector length). Hereby you find a Python example:
vector = rg.Vector3d(0,0,1)
params = rg.MeshingParameters.QualityRenderMesh
bbox = rg.BoundingBox(0,0,0,100,100,10)
mesh = rg.Mesh.CreateFromCurveExtrusion(curve, vector, params, bbox)
Attached a small internalized example:
example.gh (3.8 KB)
Hi @jobdvogel,
Try flipping the direction of your curve.
– Dale
It seems you’ve having the same issue reported here:
At the bottom of that thread is a C# script provided by @dale that provides a good solution.
-Kevin
Ah, completely missed that… Indeed this is a good solution! Thanks @dale for the code.
RH-68211 is fixed in the latest WIP
