in Rhino 8 the point dissolves the connected edges first, and the connected ngon is then selected, which you can delete with a second delete. I’m not sure why that was changed.
@tobias After RH-66485, deleting a Mesh control point does the same thing as deleting a mesh vertex or a SubD vertex or control point: it only deletes the vertex, not the surrounding faces. The end effect is that the vertex is dissolved into its surrounding faces, creating a big n-gon face.
Note that when you do that, control points in the interior of that n-gon face remain visible, because they can still be moved. So if your display mode does not show mesh edges, it will look like nothing has happened. However, the resulting n-gon should be selected. @tobias please share your file where dissolving the vertices does not work.
If you want to delete faces, you can instead:
Use the DeleteFaces command
Sub-object select faces (with selection filters or with ctrl+shift) and press “delete”. (Do not enable control points here or you will see RH-97675)
Select the control points and press delete twice
Just to make sure we’re all talking about the same thing, here’s a little strip of actions and results on a mesh at different steps of this process:
