I am working with output from drone mapping software producing a large OBJ. The goal is to clip a portion out of the OBJ. I’ve tried everything in the mesh editing toolbox: repairing, rebuilding, boolean split, etc. - no success.
Anyone have similar issues and/or found a way to perform reliable, clean splits on large meshes?
dale
(Dale Fugier)
September 9, 2024, 4:21pm
2
Hi @Vanko_Studio ,
To provide help, we’ll need to see the .obj file. Better yet, provid the .3dm file that contains mesh you want to split and the cutting object.
– Dale
Certainly! .3dm and OBJ links below…
Untitled.3dm
BlockB.zip
dale
(Dale Fugier)
September 9, 2024, 6:29pm
4
Hi @Vanko_Studio ,
The issue I see that that you don’t have a single mesh, you’ve got 20. And each of those is disjoint.
Before splitting, you’re going to need to get these meshes joined into a single valid mesh.
I’m not sure Rhino has enough tools to clean up this mess. You might need to run this through another too such as MeshLabs.
– Dale
Thank you, Dale! Unfortunately, MeshLab can’t handle these large meshes. Appreciate your time!
dale
(Dale Fugier)
September 9, 2024, 7:57pm
6
Hi @Vanko_Studio ,
Rather than using a drone-generated mesh, perhaps some existing topo mesh would be better?
– Dale
Would be great for models that don’t require too much accuracy as GIS data is only good to +/-3m or so - not accurate enough for this application.
Appreciate your help!
BrianM
September 9, 2024, 8:39pm
8
Have you tried the command ‘DeleteFaces’ to trim the mesh down to a manageable size?
Hey there, Brian - THIS WORKS! Thank you so much!
