What do you need the mesh for, and why are you modelling it as a nurbs if you need a mesh?
Rhino isn’t good at controlling meshes, here’s an example of V6’s quadmesh:
It’s all over the place…
@wim: Thanks for reply. Without using evolute tools, it is possible to do the same. Could you please suggest the manual grid points picking on to get the same kind of mesh?
@Holo: I need to export the mesh of the structure as gdf file, for use in another sw. Is it possible to mesh in another software and open in rhino again to save in the required file format?
ya, quads is what I’m looking for at the joints, something like shown in figure 2. It is possible to achieve that using panelling tools and mesh. But I’m not knowing it. Any help on to get something similar to figure 2 outcome is highly appreciated.
Hi Wim, that one shared by @rajaa, i got it. however for this joint where two tubular members are involved, i’m not getting the mesh as in figure 2. If you’ve achieved it could you please share it.?
@Vijay_KG If you like to use PanelingTools for this model, you probably would want to try to use nurbs faces instead of mesh as output. Non-planar faces are not output as mesh nor any trimming is applied to meshes. Can you share the file that produced the image above?
Looking at your model, you already produced good mesh faces. PT groups mesh face. It does NOT join them.
You just need to run the “Join” command to join all the meshes. They join perfectly and if you run “ShowEdges” command on them, they show to have no gaps between them (see image below).
As for the nurbs faces, if you like your result to be a surface that coincide perfectly with the cylinder, then you can use “AddFaces=Yes” option in “ptPanelGrid” and select the base surface with “Pull” option.
Thankyou rajaa and rhino team. I’ll try them and get back to you. if you feel any other suggestions or rhino commands will help, please keep posting… Nice of you ppl.
