Mesh and Subd selection tools
Thanks Brian
What they mean by organic pipe can be found here
As for Connecticut, I paid it here
And about the weld command, the unweld also has to say that it has a problem and is not executed correctly
And we mean about selection
Selection commands such as:
SelectInvert
Selectcoplanar
PaintSelection
SelectionGrow
SelectionShrink
There are other Selection commands in the clayoo plugin
Please consider all these commands in grasshopper too
Okay, I think this should be it’s own topic entirely. There’s an internal report that is filed that you can use as reference when asking about these developments again…
https://mcneel.myjetbrains.com/youtrack/issue/RH-42371
The plan is to get them working on meshes first as I understand it. FYI @Jussi_Aaltonen
You can now use SelEdgeLoop, SelEdgeRing and also sub-object select with Ctrl+Shift and double click to select an edge loop. This also works on face loops if a face is already sub selected and you double click a connected one.
Yes thank you
