Merging Surfaces
Hello again,
I have several surfaces, I tried to merge them by merging breps in order to get the final brep length and width, but It does not work, do you have a solution?
temp_Test_SmartOffset_re.gh (56.1 KB)
RegionUnion with flattening the inputs will do the trick…
that is perfect, thank you for your answer, and do yo know how I can find the width and length of each rectangle?
you can try this…
temp_Test_SmartOffset_RE.gh (70.7 KB)
that’s it, I wish I had as much knowledge as you have in Grasshopper. thank you so much
Have a look at this.
More than one way to skin a cat.gh (13.4 KB)
Well, I already used a solution similar to the the fourth row your file, but the third one seems more intelligent, Thanks mate
Download the file again, I have added something extra. Just wanted to show you that you have many options for the same problem. :slight_smile:
This one.
More than one way to skin a cat.gh (14.6 KB)
thank you, I understood the logic. :+1:
