Hello Everyone,
In my project, I have used Karamba to create beams going across a 2 way grid, and I’m trying to make individual brep beams as their own whole beams, but when I’m converting the karamba mesh to a brep the webbing and flanges are their own polysurfaces. and now I’m trying to figure out how I can merge those 3 pieces together.
I’ve tried merging them based on proximity, and individual lists, but I’m not super familiar with lists and data trees, or I’m sure there’s a smarter way altogether of doing this.
I’ve attached the script and a couple of images, if it helps.
Thank you!
You can use the KettyBIM Plugin to perform what you intend to do. It is a very powerful plugin. Can design curtain walls, Steel profiles, Bolts availability, drawing processing, and many more.
You might want to upload a file without the Karamba components to get better help with the mesh to brep conversion. A file with just the meshes but still in a tree structure would do.
