ChrisK
(Chris Kuether )
November 21, 2013, 2:29pm
1
The ‘dish’ in the file was made by extruding a circle, exploding to make a srf, planarsrf for the bottom, then offsetsrf solidyes.
Now it’s a good polysrf, but made from eight srfs, not just five.
When exploded, mergesrf won’t work on the cylindric srfs, even though the distance shows as 0.000.
Even when I make tolerance .1 it won’t merge.
It’s not important, but why???
ChrisKSmallDishHandle.3dm (34.4 KB)
mikolaj
(Mikolaj Jarski)
November 21, 2013, 2:50pm
2
There are only 2 surfaces in your file (open cylinder). I guess you missed something.
pascal
(Pascal Golay)
November 21, 2013, 4:04pm
3
Hi Chris- MergeSrf has pretty stringent requirements- see Help. Perhaps Join is what you are after?
ChrisK
(Chris Kuether )
November 21, 2013, 4:42pm
4
Well, I dunno how I posted that. This is what it should be
My sense is that it should have five srfs not eight.
And mrgsrf doesn’t.
ChrisK
.EightSrfDish.3dm (53.3 KB)
pascal
(Pascal Golay)
November 21, 2013, 4:57pm
5
Hi Chris- top edge and sides will merge in this setup - set Smooth=No. Explode the object, mergeSrf and pick on the edges you would like to merge- in this case presumably the two top edges- you’ll need mergeSrf twice to get the top merged to the sides. The bottom faces will not merge to anything, they will Join.
But… why?
ChrisK
(Chris Kuether )
November 21, 2013, 8:28pm
6
I’m compulsive this way. When I get a two surface cylinder when it should be just one, I make it one with mergesrf.
No ‘real’ reason.
clk
