MergeSrf With Two Edges
Is there any way to do a mergesrf that will operate on two edges? Or some sequence that does the same thing?
Here I have two surfaces that meet on two edges that I would like to merge.
Problem MergeSrf.3dm.zip (124.5 KB)
Hello- a closed surface will always have a seam in it - you only get to merge once here, then it becomes one surface.
But Iā€™m not looking for a closed surface.
Hello- see if this helps at all -
https://docs.mcneel.com/rhino/6/training-level2/en-us/Default.htm#topics/03_nurbs%20topology.htm%3FTocPath%3D_____6
