Just observed with today’s build.
Before command:
After running the command:
After stretching side elements and joining all surfaces:
Before command:
Is this reproducible? Can you post a 3dm file?
Yes it is. Happened in several files that were created in V7.
Sample attached.
MAE problem.3dm (5.1 MB)
Thanks, Piotr!
→ RH-86490 MergeAllEdges: Failure Case
Hi Wim
To be precise. It is not failing to produce correct result but is extending creases as a side-effect; so I would describe it.
Correct, I should be having the checker continuously on :-/
