Merge issue
to forum.3dm (206.7 KB) I tried to merge these edges . Anyone know what I am doing wrong? Thank you,Mark
Hi Mark,
Thanks for the file. i took a look at the edges by your dot — that boundary is split into three segments, and the two junctions where they meet kink at about 2.4 degrees. MergeEdge only merges edges that are tangent within the file’s angle tolerance (1.0 degree in your file), so it’s refusing those on purpose. The little segments further along that are truly tangent will merge fine.
If you just need them merged, you can bump the angle tolerance to 3 degrees in DocumentProperties > Units and MergeEdge will take them — but the kink is real, so it may come back to bite downstream. The cleaner fix is rebuilding that boundary with a single smooth curve and retrimming.
What’s the end goal here?? if it’s joining these surfaces up, Join doesn’t need the edges merged first.
Thanks Japhy, just wanting an explanation.—-Mark
I started with untrimmed srfs. I used fillet srf to get to the point of where it is now.
