Hi UI-people,
I wonder why the menu SubD is between Surface(NURBS) and Solid(NURBS), and not after Solid like in the toolbar:
My 2 cents,
Michael
www.flexiCAD.com
Hi UI-people,
My 2 cents,
Michael
www.flexiCAD.com
Hm - probably no good reason - which one should change?
Hi Pascal,
I would move SubD after solids in the menu (green arrow with line), because SubD is not NURBS, and it’s a new addition.
Does this make sense?
Thanks
Michael
Hi Michael - thanks, I do not have a strong feeling about what it best here, myself, but I would agree that it makes sense for these to be in a similar order to the default toolbars if possible- SubDs are somewhat more like surfaces, I guess, in the end, than like meshes; perhaps that is why that order was chosen. I’ll see if anyone here has a strong vibe about it.
I would change the standard toolbar by adding subd create and edit buttons like surfaces and solids.
And change the organization under the subd tab to respect the same organization we have for surface and solids.
At the end subd should be consistent compared to srf and solids
Check this
