I recently upgraded to V7 and i’m getting memory leaks when I start playing with the materials tab. It’s a 370mb file, and the memory usage normally sits around 1GB. Usually when I click on the materials tab (or the dropdown menu) on any object, it first takes a very long time to load the list and then the memory usage ramps up to 100% (I have 32GB) and crashes my PC. The same file in V6 doesn’t produce this issue.
Same file opened in V6 and V7
Memory leak on V7
V7 file
The same file has been saved as V6 and doesn’t reproduce the same issue in V6
DxDiag.txt (98.4 KB)
