Hi
We just started to use v7 and noticed that once we stop the program there a lot of leaks (at least there are reported as such). We tried to reproduce the issue with VS 20017 as follows:
- latest version from github (branch 7.x)
- opennurbs.h line 27 paste the following:
#define _CRTDBG_MAP_ALLOC
#include <stdlib.h>
#include <crtdbg.h>
#pragma warning( disable : 4996 ) - opennurbs_dll.cpp line 37 paste:
_CrtSetDbgFlag ( _CRTDBG_ALLOC_MEM_DF | _CRTDBG_LEAK_CHECK_DF ); - opennurbs_public.h line 50 paste:
#pragma warning( disable : 4996 ) - opennurbs_public_examples.h line 23 uncomment #define OPENNURBS_IMPORTS, to use it as dll.
Build and run example_read without parameters than check VS output.
Detected memory leaks!
Dumping objects ->
{27412} normal block at 0x0000017AB98E54E0, 8976 bytes long.
Data: < > 00 00 01 00 01 00 00 00 04 00 00 00 00 00 00 00
e:\github\opennurbs\opennurbs_public_memory.cpp(65) : {23085} normal block at 0x0000017ABDDD39B0, 24 bytes long.
Data: < e n > 01 00 00 00 05 00 00 00 05 00 00 00 65 00 6E 00
e:\github\opennurbs\opennurbs_public_memory.cpp(65) : {23084} normal block at 0x0000017ABDD26400, 100 bytes long.
Object dump complete.
The program ‘[11368] example_read.exe’ has exited with code 0 (0x0).
It seems that all global variables declared in opennurbs_statics.cpp are reported as leaks. Hoverer, I believe they are false positives, but we should be sure about. Is there anybody who faced this issue?
