I experience what I suppose is a memory leak in InstanceObject.GetSubObjects()
Below is a minimal example that should show this. If I do manually what I assume is happening more or less under the hood, it does not leak (see second loop).
if (RhinoGet.GetOneObject("Get block", true, ObjectType.InstanceReference, out var objRef) != Result.Success ||
!(objRef.Object() is InstanceObject instanceObject))
return Result.Failure;
// This leaks (loop to see the leak clearly)
for (int i = 0; i < 100; i++)
var leakingObjects = instanceObject.GetSubObjects();
// This does not leak
var nonleakingObjects = instanceObject.InstanceDefinition.GetObjects();
var transform = instanceObject.InstanceXform;
foreach (var rhinoObject in nonleakingObjects)
rhinoObject.Geometry.Transform(transform);
return Result.Success;
