I need to write a program which will split breps many times.
I found about 30MB memory will be consumed every time I call Brep.Split(), although I explicitly freed all the object I could find, so Rhino will consume several GB memory quickly and sometimes it just be forced to exit.
I’ve attached simplified test code and model, and a video to show the issue. My Rhino version is 7.4. Thank you in advance.
I have the same issue to call Brep.Split() and Brep.CreateBooleanDifference(). The memory goes up to 3GB and is only released when the RunCommand function returns Success.
@Rockwithboa Thanks for finding and reporting this. I have fixed it in version 7.8 which should be available as a release candidate in the next couple weeks. If could test this in a release candidate I’d like to here what you find. Thanks again.
