Memory Allocation Failed
Working with large meshes and point clouds.
Rhino 9 SR0 2026-4-14 (Rhino WIP, 9.0.26104.12305, Git hash:master @ 5bd7a4f16954bce589a148ccd941ced83b3638ad)
License type: Commercial, build 2026-04-14
License details: Cloud Zoo
Expires on: 2026-05-29
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 9.0.15
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 3-4-2026 (M-D-Y). DirectX(11)
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26104.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26104.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26104.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26104.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26104.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26104.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Does it load in Rhino 8? Could you share this file?
The memory allocation issue happened while working with the file. The meshes and point groups are grouped together. I was trying to Section on part of the meshes using sub-selection with a crossing box to select the objects to be sectioned when the issue occured.
After restarting the system, I opened the file in rhino 9 WIP and worked with with it for a while with no problems, and saved it. I can share the file but it it is 1.7 GB. I’ve been working with similar files which are almost as large with no problems.
Results of Audit3dmFile:
Testing 3dm Archive: D:\Elf\Rhino\Elf 111.3dm
Start Section: 468 bytes (offset 0 to 468)
Offset: 0
3dm archive version: 90
Interface Name: Rhinoceros 9.0 - Commercial, build 2026-04-14 - (compiled Apr 14 2026)
SDK Version: 2348836105.2449512121
OpenNURBS Version: 2449512121
3dm Version: 9
Operating System: Windows 11 (10.0.26100 SR0.0) or greater, 64-bit, platform 2, version 10.0 build 26100 sp 0.0, suite 768, product type 1
Runtime: ON::RuntimeEnvironment::Windows 3DM I/O processor: OpenNURBS toolkit version 2449512121 (compiled on Apr 14 2026)
Properties Section: 171385 bytes (offset 468 to 171853)
3dm archive openNURBS version: 2449512121 (9.0 2026-04-14:1)
Application Information:
URL: “http://www.rhino3d.com
Details: “Commercial, build 2026-04-14”
Revision History:
Create Time: Friday April 17 15:32:09 2026 UTC
Last Edit Time: Sunday April 19 03:07:01 2026 UTC
Revision Count: 10
Created By: “dcock”
Last Edit By: “dcock”
Settings Section: 14584 bytes (offset 171853 to 186437)
Model length unit system: inches
Page length unit system: millimeters
Plug-ins:
Name: 3Dconnexion 3D Mouse
Version: 9.0.26104.12305
File: C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp
SDK Version: C++ 2348836105.2449512121 (6.0 2017-08-15:1, 9.0 2026-04-14:1)
Version: Apr 14 2026 12:56:17
File: C:\Program Files\Rhino 9 WIP\Plug-ins\Calc.rhp
File: C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp
SDK Version: .NET 0.0
Version: Apr 14 2026 12:57:37
File: C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp
File: C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp
File: C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp
Name: Renderer Development Kit
Version: Apr 14 2026 12:54:36
File: C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp
File: C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp
File: C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp
Version: Apr 14 2026 12:57:49
File: C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp
Version: Apr 14 2026 12:57:50
File: C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp
File: C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp
Embedded image Table:
0 embedded images, 24 bytes (offset 186437 to 186461)
Texture Mapping Table:
0 texture mappings, 24 bytes (offset 186461 to 186485)
Legacy Material Table:
material[0]: ELF_Mark_Bow
material[1]: Elf_YS_A
material[2]: Elf_YS_B
material[3]: Custom
material[4]: Custom
material[5]: Custom
material[6]: Custom
material[7]: Custom
material[35]: Elf_Hull_10K26
36 materials, 36112 bytes (offset 186485 to 222597)
Render Materials:
material[0]: Elf_Hull_10K26
material[1]: Elf_Hull_10K9
material[2]: Elf_Hull_10K8
material[3]: Custom
material[4]: Elf_Hull_10K21
material[5]: Elf_Hull_10K7
material[6]: Elf_Hull_10K5
material[7]: Elf_Hull_10K14
32 materials, 384128 bytes
Embedded Files:
embedded file[0]: D:\Elf\Meshes\Elf Hull 10K.jpg, 15897360 bytes
embedded file[1]: D:\Elf\Meshes\Elf Hull 10K1.jpg, 15601388 bytes
embedded file[2]: D:\Elf\Meshes\Elf Hull 10K10.jpg, 14052491 bytes
embedded file[3]: D:\Elf\Meshes\Elf Hull 10K11.jpg, 13302273 bytes
embedded file[4]: D:\Elf\Meshes\Elf Hull 10K12.jpg, 14714509 bytes
embedded file[5]: D:\Elf\Meshes\Elf Hull 10K13.jpg, 15768349 bytes
embedded file[6]: D:\Elf\Meshes\Elf Hull 10K14.jpg, 13749604 bytes
embedded file[7]: D:\Elf\Meshes\Elf Hull 10K15.jpg, 13458119 bytes
31 embedded files, 366191291 bytes
Linetype Table:
0 linetypes, 24 bytes (offset 222597 to 222621)
Layer Table:
layer[0]: ZERO
layer[1]: Position GB
layer[2]: Position Pack Boats
layer[3]: Alignment Scaling
layer[4]: Input
layer[5]: Scale
layer[6]: Final
layer[7]: Points In
layer[8]: Hull
layer[9]: YS Marks
layer[10]: Meshes
layer[11]: Hull 10K
layer[12]: YS Marks
layer[13]: Clipping
layer[14]: Center Plane
layer[15]: Temp1
layer[16]: Temp2
layer[17]: Temp3
18 layers, 4542 bytes (offset 222621 to 227163)
Group Table:
group[0]: Group05
group[1]: Group02
group[2]: Group03
group[3]: Group04
group[4]: Group07
group[5]: Group 06
group[6]: Group 07
group[7]: Group06
group[11]: Group08
12 groups, 1576 bytes (offset 227163 to 228739)
Annotation Style Table:
annotation style[0]: Default
1 annotation styles, 1447 bytes (offset 228739 to 230186)
Light Table:
0 lights, 24 bytes (offset 230186 to 230210)
HatchPattern Table:
0 hatchpatterns, 24 bytes (offset 230210 to 230234)
Section Style Table:
0 section styles, 24 bytes (offset 230234 to 230258)
Markup Table:
0 markups, 24 bytes (offset 230258 to 230282)
Layout Group Table:
0 layout groups, 24 bytes (offset 230282 to 230306)
Block Definition Table:
0 block definitions, 24 bytes (offset 230306 to 230330)
Object Table:
object[0]: 591 bytes, id = 38f3a00d-cde1-4556-a27a-21fdf267de3c
object[1]: 591 bytes, id = 565faf8e-6add-4ab8-ab1a-933931efab8b
object[2]: 591 bytes, id = c799637c-055a-4cf1-a1fe-0f2d3efb4060
object[3]: 227 bytes, id = 16735c55-0c21-497b-b03d-46dc6fef4074
object[4]: 175 bytes, id = 35a0db55-602e-4868-83f6-83ec4b32ea9e
object[5]: 219 bytes, id = 4529a9d7-089f-4a7c-be53-04cdca2be87a
object[6]: 219 bytes, id = f373986c-8ce9-46ff-9b12-7b55c8d9b6e5
object[7]: 227 bytes, id = d28c98d7-7310-44e7-9eb8-09fca4d61d60
object[8]: 175 bytes, id = a31b4637-b923-4e5d-9616-9213c5ee040a
object[9]: 219 bytes, id = d0d4452e-8f1d-4f12-bf8e-5f824292735d
object[10]: 219 bytes, id = abcaf3f3-73c3-4d53-9688-1d88f9bd9c07
object[11]: 595 bytes, id = 7af8885b-391f-4323-ae50-2e8e6a4e03e4
object[12]: 595 bytes, id = a7719aea-a501-4fd4-9e55-733a0a8bf943
object[13]: 595 bytes, id = bf24789b-78b8-4d3c-bb08-55ae3c574059
object[14]: 4057 bytes, id = 50450506-ad2e-437b-b963-ec31a60dccf0
object[15]: 219 bytes, id = 88748912-f59d-41c7-96d9-d5045004ff7c
object[16]: 595 bytes, id = c39702ff-087d-4ac3-aac4-45af1302af3d
object[17]: 595 bytes, id = b2c3042f-4892-471a-bb49-6cc637a46e16
object[18]: 595 bytes, id = 1fb3df85-3c77-484d-83c9-088d9de48fbf
object[19]: 876254 bytes, id = 72292356-f4d8-459f-90cd-7906ddbd484b
object[20]: 2312938 bytes, id = 9644edea-9b36-4d90-a9e7-d41724bb9e6f
object[21]: 4642938 bytes, id = ef2a8197-81a4-4914-b081-ff780c4b164c
object[22]: 807011693 bytes, id = 353c4c5a-7e46-46d9-9384-ed728582a512
object[23]: 1414037 bytes, id = 2ea9a739-a67c-4197-be5a-41865eb540d8
object[24]: 441765 bytes, id = c46e1ee7-e704-44b5-9af0-c8a5b4f5b5e8
object[25]: 1219325 bytes, id = fb8047a5-5369-4d40-b423-a2432801ab3b
object[26]: 2752409 bytes, id = 831acf6d-d34e-44ed-98dd-1c2697ced88c
object[27]: 491442 bytes, id = 611654ac-90b5-49e2-8292-2af8bbe4e60f
object[28]: 21762562 bytes, id = e3a8c382-dfd5-48dc-8044-8b1945528b45
object[29]: 23697574 bytes, id = 36114feb-bef6-4aff-9b8b-f4cc23d38666
object[30]: 27095006 bytes, id = 582c4ed9-e242-4206-92b0-7c5f23622964
object[31]: 19582926 bytes, id = 79df8f8c-95de-4af7-8bd9-13f99726b0a7
object[32]: 30898666 bytes, id = 1b27ea22-9f59-44aa-aa7b-1b223468c822
object[33]: 28069258 bytes, id = 50faf520-6290-4e83-8da4-8928300dd513
object[34]: 32649426 bytes, id = 75b7b251-b688-4538-9e93-6f1e186d1a35
object[35]: 18013414 bytes, id = 3c517cd2-9b66-4744-85c9-37e1380aaa0f
object[36]: 18328778 bytes, id = 70a48cc0-4a49-4388-b072-cfc4d7c4ffa8
object[37]: 15307466 bytes, id = 9e569997-5278-41f6-9008-7153ac22c528
object[38]: 15592102 bytes, id = 102520ea-11ee-4bba-9ced-7e8726f1c68a
object[39]: 20331722 bytes, id = c035389f-7595-4efd-964a-b98da99ee9ff
object[40]: 32792050 bytes, id = c6afcf1f-88b9-4b33-8795-2e292c17de9e
object[41]: 20472622 bytes, id = 7b44f831-bfcf-423b-9a90-c93546848dbc
object[42]: 18256414 bytes, id = c7dc0de1-32a8-40a1-80c9-1bfe45df76ee
object[43]: 16041666 bytes, id = e59fcee6-b1f4-4f9f-9fe5-3138a0251bf2
object[44]: 10655626 bytes, id = 55c7438c-c1df-4ed7-a4a1-3cdf42531800
object[45]: 13453226 bytes, id = d4d010d4-3f17-47b0-b402-a0af3ef59fd0
object[46]: 10872362 bytes, id = 8e041f18-9b2a-4170-a5aa-4ec04f1274c8
object[47]: 24364978 bytes, id = f25a2f9b-8403-4d2f-a46c-578d79813d91
object[48]: 24692418 bytes, id = 6c0322d5-f9a4-4da4-ac19-756733eb658f
object[49]: 22790670 bytes, id = b0962ea3-062d-452d-bfb8-7965882eba16
object[50]: 28656802 bytes, id = adb6ae36-0df2-4899-b8c2-5ef880f74218
object[51]: 22299350 bytes, id = 657fc0ac-0aa7-4af0-8fc0-93498af6fc5d
object[52]: 20877050 bytes, id = c0a5cc2c-eedb-4b0a-b0bb-50515cfbf18b
object[53]: 22517322 bytes, id = 97b13b31-7e16-4665-b6f9-e60229dd56fd
object[54]: 14410098 bytes, id = 3102f1d4-d786-4971-9ae9-8f06c2a0d15a
55 objects with 9 plug-in data items, 1395655678 bytes (offset 230330 to 1395886008)
History Record Table:
0 history records, 24 bytes (offset 1395886008 to 1395886032)
Model User Data Table:
user table[0]: (366614542 bytes)
Plug-in name: Renderer Development Kit
Plug-in id: 16592D58-4A2F-401d-BF5E-3B87741C1B1B
user table[1]: (33542 bytes)
Plug-in id: 8B62C204-C421-4422-BE79-085DDF05F02B
2 user tables, 366648286 bytes (offset 1395886032 to 1762534318)
Archive size = 1762534338 bytes (end mark size = 1762534338)
Just tried again and same issue. Maximum memory usage hit “99%”. First time this system has run out of memory.
What results for the group of meshes and point clouds:
curve
Object name: (not named)
Layer name: Alignment Scaling::Final
Render Material:
source = from layer
index = -1
Groups:
Group 06
Group 07
Group08
Attribute UserData:
UserData ID: B63ED079-CF67-416c-800D-22023AE1BE21
Plug-in: Renderer Development Kit
description: RDK data
saved in file: yes
copy count: 51
Geometry:
Valid curve.
Line
start = (201.251,18.326,196.424)
end = (630.948,19.676,197.346)
domain = 0.000 to 24.000
line length = 429.700
curve
Render Material:
source = from layer
index = -1
Groups:
Group 06
Group 07
Group08
Attribute UserData:
saved in file: yes
copy count: 51
Geometry:
Valid curve.
Line
end = (201.021,18.326,303.849)
domain = 0.000 to 6.000
line length = 107.425
curve
Render Material:
source = from layer
index = -1
Groups:
Group 06
Group 07
Group08
Attribute UserData:
saved in file: yes
copy count: 51
Geometry:
Valid curve.
Line
end = (200.239,340.599,196.422)
domain = 0.000 to 18.000
line length = 322.275
mesh
Layer name: Meshes::YS Marks
Render Material:
source = from obj
index = 0
Groups:
Group10
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 9647 vertices, 17800 faces
Bounding box: (346.354,2.207,21.532) to (359.210,3.279,28.034)
mesh
Render Material:
source = from obj
index = 1
Groups:
Group10
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 25496 vertices, 46820 faces
Bounding box: (167.170,4.915,0.048) to (204.328,7.848,1.971)
mesh
Render Material:
source = from obj
index = 2
Groups:
Group10
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 55952 vertices, 48738 faces
Bounding box: (276.223,14.034,-6.686) to (313.357,16.946,-6.011)
point cloud
Layer name: Points In::Hull
Render Material:
source = from obj
index = 3
Groups:
Group01
Group08
Geometry:
Valid point cloud.
Point cloud with 28821833 points.
(139.978,51.559,78.802), (139.992,51.305,78.576), (138.041,50.588,78.559), …
Geometry UserData:
UserData ID: 769DDDD4-1756-4c95-A026-8E975D704AEA
description: MyTreeUserData
saved in file: no
copy count: 0
point cloud
Layer name: Points In::YS Marks
Render Material:
source = from obj
index = 4
Groups:
Group12
Group01
Group08
Geometry:
Valid point cloud.
Point cloud with 50488 points.
(347.737,2.819,20.830), (347.665,2.829,20.894), (348.396,2.782,20.724), …
point cloud
Render Material:
source = from obj
index = 5
Groups:
Group12
Group01
Group08
Geometry:
Valid point cloud.
Point cloud with 15764 points.
(139.301,2.793,15.111), (139.301,2.812,13.900), (139.540,2.799,13.174), …
point cloud
Render Material:
source = from obj
index = 6
Groups:
Group12
Group01
Group08
Geometry:
Valid point cloud.
Point cloud with 43534 points.
(176.531,6.777,0.982), (176.768,6.779,0.847), (176.537,6.763,0.997), …
point cloud
Render Material:
source = from obj
index = 7
Groups:
Group12
Group01
Group08
Geometry:
Valid point cloud.
Point cloud with 98287 points.
(283.803,15.928,-6.350), (284.053,15.952,-6.358), (284.046,15.828,-6.370), …
mesh
Render Material:
source = from obj
index = 8
Groups:
Group10
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 5380 vertices, 10235 faces
Bounding box: (131.987,2.472,13.276) to (140.287,2.931,18.440)
mesh
Layer name: Meshes::Hull 10K
Render Material:
source = from obj
index = 9
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 205958 vertices, 381817 faces
Bounding box: (45.360,-69.145,1.757) to (471.135,64.141,122.168)
mesh
Render Material:
source = from obj
index = 10
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 223073 vertices, 421459 faces
Bounding box: (44.964,-60.622,2.014) to (471.182,68.653,117.967)
mesh
Render Material:
source = from obj
index = 19
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 257291 vertices, 471263 faces
Bounding box: (45.241,-69.188,1.031) to (434.934,68.042,118.323)
mesh
Render Material:
source = from obj
index = 20
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 187871 vertices, 331503 faces
Bounding box: (44.937,-69.119,4.415) to (453.976,65.429,117.930)
mesh
Render Material:
source = from obj
index = 21
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 297572 vertices, 517657 faces
Bounding box: (45.216,-64.938,1.855) to (478.121,66.650,131.371)
mesh
Render Material:
source = from obj
index = 22
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 266576 vertices, 488050 faces
Bounding box: (51.392,-69.270,1.612) to (397.204,67.427,115.042)
mesh
Render Material:
source = from obj
index = 23
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 310962 vertices, 563477 faces
Bounding box: (183.809,-69.218,4.692) to (471.067,49.751,122.597)
mesh
Render Material:
source = from obj
index = 24
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 171385 vertices, 311717 faces
Bounding box: (104.218,-69.201,1.029) to (399.139,67.241,118.323)
mesh
Render Material:
source = from obj
index = 25
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 173228 vertices, 322673 faces
Bounding box: (47.496,-69.318,2.139) to (427.360,57.858,116.986)
mesh
Render Material:
source = from obj
index = 26
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 145512 vertices, 265492 faces
Bounding box: (91.235,-69.170,1.409) to (379.738,66.414,115.179)
mesh
Render Material:
source = from obj
index = 27
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 148077 vertices, 271098 faces
Bounding box: (44.992,-66.647,12.043) to (458.887,66.422,109.381)
mesh
Render Material:
source = from obj
index = 28
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 191672 vertices, 360248 faces
Bounding box: (89.933,-66.766,1.105) to (467.404,56.254,127.024)
mesh
Render Material:
source = from obj
index = 11
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 314794 vertices, 554189 faces
Bounding box: (45.106,-66.178,0.754) to (471.170,68.847,122.764)
mesh
Render Material:
source = from obj
index = 29
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 192063 vertices, 367197 faces
Bounding box: (45.362,-66.711,1.863) to (427.843,63.365,105.203)
mesh
Render Material:
source = from obj
index = 30
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 172315 vertices, 322487 faces
Bounding box: (45.323,-49.121,1.030) to (333.696,66.997,110.449)
mesh
Render Material:
source = from obj
index = 31
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 149982 vertices, 290147 faces
Bounding box: (91.625,-68.730,1.248) to (422.126,43.548,99.609)
mesh
Render Material:
source = from obj
index = 32
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 100348 vertices, 189281 faces
Bounding box: (45.229,-64.021,1.245) to (390.459,7.854,112.491)
mesh
Render Material:
source = from obj
index = 33
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 127284 vertices, 236185 faces
Bounding box: (63.888,-68.425,1.853) to (413.504,68.755,108.462)
mesh
Render Material:
source = from obj
index = 34
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 102884 vertices, 190781 faces
Bounding box: (62.209,-67.123,1.043) to (427.391,68.781,108.465)
mesh
Render Material:
source = from obj
index = 12
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 234530 vertices, 408751 faces
Bounding box: (90.372,-69.174,3.150) to (343.214,68.713,114.436)
mesh
Render Material:
source = from obj
index = 13
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 235682 vertices, 423744 faces
Bounding box: (45.159,-69.324,2.982) to (471.098,64.839,122.600)
mesh
Render Material:
source = from obj
index = 14
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 217603 vertices, 390760 faces
Bounding box: (93.352,-69.130,1.109) to (458.431,68.753,118.108)
mesh
Render Material:
source = from obj
index = 15
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 272634 vertices, 495996 faces
Bounding box: (45.257,-69.156,2.675) to (452.697,51.585,117.933)
mesh
Render Material:
source = from obj
index = 16
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 211201 vertices, 390462 faces
Bounding box: (49.386,-69.246,0.845) to (380.295,64.070,114.759)
mesh
Render Material:
source = from obj
index = 17
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 198236 vertices, 363152 faces
Bounding box: (45.082,-69.309,2.150) to (409.048,64.057,114.645)
mesh
Render Material:
source = from obj
index = 18
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 215080 vertices, 385660 faces
Bounding box: (45.572,-66.811,2.006) to (427.818,63.612,115.415)
mesh
Render Material:
source = from obj
index = 35
Groups:
Group06
Group01
Group08
Geometry:
Valid mesh.
Open double precision polygon mesh: 134602 vertices, 261229 faces
Bounding box: (45.109,-66.981,23.479) to (343.501,61.431,106.643)
Mesh totals: 31 meshes, 5554890 vertices, 10100068 polygons
