Hello Dear Rhino Users:
I am relatively new to rhino and trying to create a medical mold with using Rhino’s flexibility. Rhino has served my purpose incredibly well so far. But I have an important set back. I have a shape that I created with medical Imaging as STL file type.
I took the offset of Initial shape and fitted it in a box, then I took the Boolean difference (cutting obj. was the offsetted initial shape) after that I needed another Boolean operation to cut the mold in to two pieces.
I needed a vertical cut but it is not a straight vertical cut, kind of an S shaped cut. So I created the S shaped surface and tried the Boolean Split and it failed. But when I do the same thing with the initial shape it worked. But I need to split the offsetted version
https://drive.google.com/open?id=1Nyyt_SYll_QVom0bFXQRAJgpDWB5AoEk
