Measurement
Is there a solution to the measurements in Rhino ? Measurements are shown under furniture or anything
Hi @jon-vrin,
This is the problem of using model dimensions directly in the 3D model in Rhino, at least using shaded or hidden display model.
You can try to move dimension to the same elevation as the cut-plane.
IMHO, the best option is to use dimensions in layouts (outside the details), or over VisualARQ plan views objects.
Enric
Hi @jon-vrin, you can also use the Rhino command _BringtoFront, to see the dimensions over the rest of the objects, regardless of their position. But of course they will be visible also when you are in other levels. If you place these dimensions in different layers according to levels, you can manage their visualization by Detail viewport in page layouts.
thanks alot :slightly_smiling_face:
