Measurement display
hello, a query about display precision.
Using Version 7 (7.4.21078.1001, 2021-03-19).
If i have a measurement of an object length showing in ‘box edit’ as say 25.125mm, then i use 'Dimenion>Linear Dimension to measure it, it will only display the first two digits after the dot, i.e. 25.12mm. Ive had a trawl through settings and tried a few things but i cant seem to alter the way it displays to only two decimal places. Any ideas, thanks.
Hi, this is how to do it. You have to change the “Linear resolution”. Optionally, you can also activate “Suppress trailing zeros” to get rid of the unnecessary zeros at the end of the whole numbers.
thank you so much…i did experiment here but i think i may have forgot to press ‘apply’! cheers :slight_smile:
