I’m experiencing an issue in Rhino 8 for Mac where measurement commands are not working correctly, and I’m hoping someone can help.
- ‘Distance’ command only shows the dx / dy / dz differences, but does not return the total distance value.
- ‘Length’ and ‘Area’ commands do not return any result at all. Scrolling through the command history / command window does not show the measurement results either.
After reinstalling Rhino, the measurement commands work correctly at first, but after some time the issue returns. Based on my recollection, the problem seemed to reappear after importing a SketchUp (.skp) model, although I’m not completely certain that this is the direct cause. Once the issue starts, it affects multiple files, not just a single document, and restarting Rhino does not resolve the problem.
Has anyone encountered a similar issue, or is there a known setting, preference, or bug that could cause measurement results to stop displaying like this? Any help or insight would be greatly appreciated. Thank you in advance.
Woo
Rhino 8.27.25357.11372 (2025-12-23)
macOS Sequoia 15.5 (24F74)
MacBook Pro M4 Max
