I wonder if there is a possibility to measure the angle directly that should be used for rotating a hatch? Like measuring an angle with Angle it would be helpful to define the rotation with two lines. Currently, this measurement has to be done separately before insert the value manually.
I don´t do this too often, so there is no great need for a “special” solution. I just wondered if this is something that could be implemented because I need it occasionally.
