Measure Clash parameters
Is there a way to measure the parameters of the clash between two objects. In the attached file if one sets the Clearance distance to zero it seems that the shaded area represents the extent of the clash. But then is there a way to measure the length, width , depth of the shaded clash part? Or perhaps another approach is possible / needed e.g. make a copy of the objects and then run a Boolean command where what is left is the intersecting [clash amount] part.
Thank you,
Andy
clash_depth.3dm (448.6 KB)
