Question, is there a tool (or workaround) to get multiple ‘points’ in the MD slider (or comparable tool)?
So for instance I would like to define 3 points, like shown below;
Besides, would it be possible to set manually a coordinate? (so that the coordinate below is 3;5 instead of 2,99 4,98)
any suggestions? thanks
You could just type those coordinates into a panel.
Thanks, yes I know but It is input for a design/geometry. Whereby I would like to ‘play’ visually around with these points by sliding these points of the geometry.
Do you have any suggestions?
thanks again :).
diff-arch
(diff-arch)
June 20, 2020, 7:21am
4
Alternatively to Michael’s proposal, you could simply create three individual Graph Mapper components and merge their outputs with a Merge component.
ruud.vanknippenberg:
You can change the domain and values of a Graph Mapper by double-clicking it. A menu will pop up.
Oke thank you.
I thought maybe it would be possible to have it in 1
thanks.
You could also make your own like the following:
MDSlider Rhino.gh (17.4 KB)
