MCPConnect
Hi all, I have install the Rhino-MCP-Platform. It works well in Rhino and Grasshopper. But when I try the samething under Revit 2024 Rhino+Grasshopper, it doesn’t work. AI told me because the Rhino & Grasshopper in Revit 2024 is built under different .net environment… I wonder if there is a solution for that? Is that possible to has a different version of MCP which match with the Rhino & Grasshopper in Revit 2024 and also keep the MCP match with a common Rhino & Grasshoper outside Revit?
It has to be built in different .net environment.
@CallumSykes can guide you on this better.
Why not using Revit 2025?
What .net version does Revit 2024 use?
.networkframework 4.8
Because when the project started two years ago, it was decided that Revit 2024 would be used, and because of worksharing, we cannot upgrade the model separately to a higher version of Revit.
Ah, I see, I haven’t pushed a version since I added net4.8 support.
I’ve just pushed 0.4.0 which should work for you @Jack_Zeng
Cool, thanks Callum!
