Does VisualARQ already have an MCP server that allows an AI agent to read, create, and modify architectural VisualARQ elements in Rhino?
McNeel mcp should work with VisualARQ objects as well, as long as the methods are exposed in the VisualARQ api. Or you could just create gh scripts with VisualARQ components.
@Toni_Osterlund do you mean this: GitHub - mcneel/RhinoAI: AI features for Rhino · GitHub ?
Tokens/usage cost is extremely high when you involve AI with VisualArq, and practically you cannot do many things accurately without a hundred of iterations and finally you will reach to a point using rhino geometry only, because there is no proper documentation for the native commands, VA is highly dependent to panel pop-ups for most of the commands, there are no alternatives for silent commands via the command line alone, and the API exposed is entirely limited with gaps here and there and also Grasshopper components do not provide the same settings as the native ones.
@Sander_van_Lanen if you want add your votes on this thread:
Hi @GabrielB
I have still very limited experience with this, but with my current understanding I disagree with your view.
I think this is the same as your link.
This is a direct creation without gh.
Though everything is not exposed to API, I agree with that. But generally VA+gh is a very powerfull combination. I’m still very much exploring, and agree to general limitations - but I see big speed benefits as well.
Yesterday I created this set on 37 sections with AI, made the views manually, dimensioned 2 of them as example, and AI dimensioned the rest.
So, I’m not trying to solve the world at once, but incorporate speed benefits into the process.
EDIT: I have to point out the shortcoming in the last process, that you also mention. I tried to create the sections in Rhino, but because of lack of scriptable command, the popups prevented it. So Instead, the section locations were computed inside Grasshopper.
We agree there are limitations. I am not talking from the point of view of a user exploring possibilities. Of course you can create such things. I am talking about metrics, usage time consumption. Do you agree that feeding a proper documentation to the agent would cost less in time -tokens-rate ? Ai is doing great on rhino native elements such as dims because there is strong documentation for devs and a complete api system. Have you seen the rhino one compared to VA’s? Please try to apply via grasshopper every single setting that is available through native panel you’ll see that there are many of them. Maybe at skme time i can provide a list. Please try to toggle guides off via AI. I’ve got four plugins sitting and waiting for numerous API related not exposed commands - one with highly documented workflows combining VA with energy metrics and quantity takeoffs and one to connect accurately codex via panel-chat.
edit: @Toni_Osterlund by the way, you seem to be the master of workflows involving sectioning, as in other threads, you’ve presented nice examples of automation. Do not get me wrong on this, you can certainly do things faster these days, but the next step is accuracy, speed and cost of tokens. There are things we could keep listing here. A proper documentation and relation 1:1:1 among the three ways to work with VA, could benefit all VA users.
@GabrielB
Let’s call me a niché user of VARQ, so I am blissfully unaware of all the limitations of the intended proper modelling process. Therefore as I understand your pain-points, I probaby have different bottlenecks in my processes. I agree with your request towards the Asuni team, as you more propably represent the ‘normal’ user.
As I said, I’m still very noob to this ai thing - I’ve constructed python scripts for a long time, but not have had direct access to Rhino for long. Accuracy is the key, as you mention. Therefore I also tread litely and with small, verifiable steps.
Hi @GabrielB,
We’re currently discussing with McNeel how VisualARQ could be integrated with RhinoAI, McNeel’s official MCP server for Rhino. We don’t currently have any plans to integrate VisualARQ with other third-party MCP servers.
At the same time, we’re working on a new, complete C# API compatible with RhinoCommon, rather than the script-based API we currently have. The idea is that both VisualARQ commands and the entire UI will be implemented using this API, so essentially all VisualARQ functionality will be exposed through it.
We’ll also implement the Grasshopper 2 components using this API, which will allow us to do more than is currently possible with Grasshopper 1.
Unfortunately, all these new features will only be available starting with VisualARQ 4, and for Rhino 9 and later. My intention is to publish a first WIP early next year, but we can’t promise anything yet.
So yes, we’re already working on VisualARQ 4, and I must admit that AI is helping us move a little faster, although we’re being quite cautious about how we use it.
Enric
Hey @enric .
Great news. Even though VA 4 seems to be far away - or not ? that’s great news. WIP on early 2027, sounds good. But do you think that the official version 4 can follow on the same year or not? Because WIP cannot be reliable, as you already know, for commercial-professional use.
As you may remember from our call some months ago, I’ve invested personal time, effort and resources in creating a series of plugins, in order to establish a holistic workflow. Of course I made some digging with AI on the script-based API. And I have specific gaps I’ve already emailed to you. What I would like you to consider doing, is until we have a working system with VA4, maybe you could expose the API from my list. It would be very helpful for me if you could expose at least on/off toggle for guides via API.
I personally do not have problem with transitioning once more from the script-based to the compatible with RhinoCommon, which is great. Even though that’s the problem with personally investing time alone on scripts and plugins. When the VA dev is changing something, then our work is useless.
So this is the reason I am spamming with the 1:1:1 relation between native commands:grasshopper components:API, with this thread: Native - Grasshopper - API relation . Please I’d like some comment of yours on this or a confirmation that you understand the reason I am pointing out this to you guys. The mcp server should rely on a solid basis, such as a ruling system and availability of settings among the ways you can create geometry. Do you want me to invest time and effort to present to you some examples or you already know what I am talking about? A small and silly example is setting WALL layer bottom and top offsets from grasshopper component byobject, as you can normally can do via native command. Every single setting you can put on a geometry creation via native command, feature-wise, should be synced in the grasshopper itself and also in the API system. Does this make sense to you? What would it mean development-wise?
As far as i understand, native commands features will lead the way for the API system commands which will lead to the grasshopper components inheriting the API system. So the 1:1:1 will be the absolute rule, right?
MCP server, from my experience should be accompanied with specific SKILLS.md rules, and specific rules in general, but also in order to be able to control the way the user wants, setting custom libraries of skills should exist as an option to the user. For example creation of VA geometry, is something that can be done with various ways. Native commands are only available with clicking on panels, this is very difficult for AI to follow. Silent commands should be provided for this reason also, via command line only too. API of course works nicely with native commands. But what about grasshopper? Grasshopper works entirely separately from native and API, because of different inputs, and many times conflicts between referencing objects that are nateviley created, for example grasshopper walls do not get accurate intersections already performed via native system. All these need to be studied prior to publishing a mcp system that seems to work. Because at that point the cost of using a model is enormous because the AI does not know what to do. In the MCP race, all current mcp servers - ai plugins fail on this, and the best is the one that has all the rules set and described 100%. It will be very difficult to have an mcp for VA prior to setting the best available basis on how VA is actually working with geometry-information etc.
So in my opinion, the wip version of an mcp for VA and the official VA4, is far away from having something solid. And maybe the gap will be like 2 years+. But anyway, the news are great. I am looking forward to your response on the above
