Why not right? You can build it in a day… apparently.
You could use the IntelliCAD (or other) engine. Or your own. The issue with AutoCAD clones is that they aren’t polished and toss bugs at you at random (often the worst) times. A new release might fix some bugs but introduce new ones. It’s otherworldly that none of AutoCAD’s competitors were able to capitalize when Autodesk started charging ridiculous subscription fees.
I don’t know what the percentage is, but a lot of resources are tied up with “Rhino Inside… ”. A connector to 2D CAD allows access to the CAD’s superior 2D detailing and annotating capabilities. But having to pay thousands of dollars per year… If McNeel can charge what they do for Rhino 3D, your basic CAD program should cost $500 ONE TIME - not some bug riddled mess where they try to charge you “Maintenance” fees while claiming the license is “perpetual”.
There’s definitely a market because everyone is either overcharging (egregiously) or failing and resorting to mass-marketing tactics. People just want a solid basic 2D CAD. One designed with a Rhino connector in mind that also doesn’t break the bank would be pretty awesome!!
