Hi, I don’t understand if there is a problem in Rhino.Propertylistbox method.
try the following code:
Call Main()
Sub Main()
Dim propbox
Dim arritems,arrvalues
arritems = array("A", "B", "C")
arrvalues = array(1, 2, 3)
Do
propbox = rhino.PropertyListBox(arritems, arrvalues, "HELLO")
If isnull(propbox) Then Exit Do
Loop
End Sub
there is a do-loop code. normally if I press OK the software shows again the propertylist box it’s correct. The same if I press Cancel button the software exit from the cycle correctly. The problem is if I press right mouse button. the software enters in a loop and stops to work.
if I try with other similar method (ex. Multilistbox) to press right mouse button it’s the same to press cancel button and there are no problem.
Have you the same result?
thanks!
Andrea
