I want to work the function by triggering the button.
Therefore, Is it possible to stop executing it ?
Of course this is possible. But I would recommend to use the Esc key for aborting a long-running process, instead of the RMB, because this is more like other Rhino commands work. Indeed, the RMB is typically used as replacement for the Enter button to re-run the last command.
To do this you must run the long-running process on a separate thread and abort the thread when the user has pressed Escape.
Thanks!
It seem a little difficult for me. I need to think this process.
Thanks !
