Maximize View at Rhino startup C++
Hello developers,
do you know how I can maximize a view at Rhino startup using C++ code in a plugin?
Some time ago I found this link:
that explains how to mazimize a view in Rhino using C++. However, I’d need to mazimize the perspective View at Rhino startup without pushing any button. In other words once my plugin is installed I’d like that every time I open Rhino I found the Perspective view maximized (and with the shaded view mode selected). Many thanks!
Hi @g_v_c,
What you ask requires a couple of event watchers. I’ve attached a sample project for you to review.
Test.zip (31.9 KB)
– Dale
Ok Dale, thank you!
My problem has been solved thanks to the project you attached to the last post.
