Matplotlib cannot generate figures
Hi, I’m trying to use the matplotlib module in the new ScriptEditor in Rhino 8. When I use the command plt.show() I get the following error:
UserWarning: Matplotlib is currently using agg, which is a non-GUI backend, so cannot show the figure.
Is there any workaround for this?
P.S. here a minimum working example:
# r: matplotlib
import matplotlib.pyplot as plt
plt.plot([0,1,2],[10,23,45])
plt.show()
Hi, I tried running your minimum working example (found this thread after unsuccessfully trying to plot from a more complex script), which did run, but Rhino 8 (the released version, not the WIP anymore) crashed with this lovely out of memory warning.
I run Rhino on an M1 Max MBP with 64GB of memory, so it would be a shame if this plot would kill it.
Can someone at McNeel take a look or provide guidance how to get matplotlib working with Rhino?
Thanks!
(My desired use case would be to use it to plot various energy simulation results from Honeybee.)
Hi ! @GIOVANNI_PAGNON
My personal workaround is to use plt.savefig() instead.
Then use other components to read the image back with a given path.
I’m doing building physics so I personally use the image viewer in the Ladybug Tools, but I guess there are other alternative components.
The link above mentioned a more hard-core method but I didn’t test. But I guess it could be helpful if you want to explore more choices.
Great idea, I always forget that the image viewer shows anything you throw at it…
I’m curious about what you do!
There is the youtrack page for this bug, it was opened a while ago but if you want to stay updated on the progress I guess here we can get the latest info:
https://mcneel.myjetbrains.com/youtrack/issue/RH-74046
RH-74046 is fixed in Rhino WIP
