Hi! I sent a file on another device via WeTransfer. When opening it, I discovered that the materials aren’t showing properly. I also received a message saying that the file has missing materials. I thought that they will be permanently embedded within the file.
I am currently using Rhino 7 Application.
Hello - you need to make sure when saving to include the texture files - run SaveAs and you’ll see the setting in the dialog.
