Materials Linked Block is not updated by Block Manager
I inserted A.3dm into B.3dm
and then I insert B.3dm into C.3dm
While I am working in C.3dm,
I changed some materials and it’s assignment and Save into “A.3dm”. and then closed “A.3dm”
I called blockmanager in C.3dm, and I updated B.3dm
I thought that the materials of A.3dm I changed should be updated after that,
but they were not updated.
Is that expected result for this function?
Hi Katsu- if you Save and reopen C, does the change in A show?
Hi pascal,
Yes, it does.
Hi Katsu- OK, I guess that is a workaround for now- use Save then Revert to see the changes. I’ll see if we can fox this- thanks for the report.
Bug report: http://mcneel.myjetbrains.com/youtrack/issue/RH-24041
Hi, pascal.
Thank you very much.
