Materials in Rhino 9 look ugly in Grasshopper
Why do Rhino materials look so ugly in Grasshopper in Rhino 9 (beta/WIP), whereas I didn’t encounter this issue in Rhino 8?
-Robert
Hi. Could you post an example (possibly simplified) to show the behavior your seeing?
I create an object in Grasshopper and connect its geometry to a Custom Preview component, where I select a material from Rhino; I get one result in any Rhino 9 scene (not just with this specific object), but a different result in Rhino 8 (even when doing exactly the same thing).
The same object:
By the way, could my own display mode be to blame for this?
-Robert
Yes. It’s quite possible that your display mode could be the culprit. I would need to see the GH definition plus and Rhino file which also contains the referenced material in order to help you troubleshoot this.
standard display mode in Rhino 9, and everything is working; I figured out what the problem was—it turned out to be the lighting settings for my custom mode.
-Robert
