Materials from RH7 to RH 8?
How do I get my materials from RH7 to be available in RH 8? I copied the folder C:\Users\XXX\AppData\Roaming\McNeel\Rhinoceros\7.0\Localization\en-US\Render Content
over to
C\Users\XXX\AppData\Roaming\McNeel\Rhinoceros\8.0\Localization\en-US\Render Content.
But the materials don’t show up.
Hi @CalypsoArt,
You can navigate to the Rhino 7 Render Content folder when using ‘Import from material library’ in the Materials panel…
You can also use the File Explorer panel to add a custom folder to that location if needed…
I hope that helps.
Thanks. I was expecting to see the “Wood” folder within the render content folder to show up in this panel.
You’d have to use the File Explorer panel for that.
