Hi Karamba,
i am writing some c# code that creates a karamba model.
The constructor of FemMaterial_Isotrop expects kN/m2 for the Young´s modulus.
According to the documentation (1.3.2) the method E() is supposed to return kN/cm2, but it returns the Young´s modulus in kN/m2.
Have there been API changes? Is this a typo in the documentation?
Thanks for your help.
Tilman
Ok, i think it´s a typo in the documentation.
It should be kN/m2 also in the method E().
Can someone confirm?
Probably the test/example under https://github.com/karamba3d/K3D_tests/blob/master/KarambaCommon_tests/Materials/Materials_tests.cs is a bit misleading then.
Young´s modulus of steel should be 210000000kN/m2 ?!
var materials = new List { new Karamba.Materials.FemMaterial_Isotrop(“family”, “name”, 210000000, 10000, 10000, gamma, 10, 0, null) };
Hello @tilman.reinhardt,
thanks for the input! You are right there is a typo in the documentation. It should be kN/m². I will also change the value in the test. Sorry for the inconvenience.
– Clemens
Hello @tilman.reinhardt, could you tell me the page number so that I can remove the typo? Thanks!
– Clemens
Hi Clemens,
ich beziehe mich auf die 1.3.2 SDK Dokumentation:
Ich denke mal, das trifft auch auf G, fy, etc. zu…
Btw gibt es davon eine aktuellere Version?
Grüße
Til
Hi Til,
thanks for the hint! We are currently preparing an on-line version of the SDK documentation and the scripting manual.
– Clemens
