I just discovered this accidentally. I rotated the face of a block while in a rendered viewport, and when I used ctrl+z to undo, the material turned black. There doesn’t appear to be a way to get out of this scenario, other than changing the material.
Hi Dan - so, make a box, as a brep, apply a material. sub-object select a face and gumball rotate it, Undo… you used the word ‘block’ in your post above - the clip does not seems to be about blocks unless you are in BlockEdit, but either way here it does not do what you show - this is a later build so it may just be fixed.
Sorry, I shouldn’t have used the word block. It’s just a simple box. I can’t get the CNC aspect of what I do out of my head. I draw a box and I think of it as a “block” of material.
I just noticed that I don’t even have to rotate. I can do anything, like add a fillet, and undo, and it goes black. It seems more connected to the undo function than anything else.
But like you said, maybe it’s fixed in the next build. I’ll watch for it.
Hi Dan - does the material render (full render) correctly when it displays black? I’m guessing yes, but… (that will help be decide which of the bigger brains to bug about this)
You guessed correctly. The full render, and even the render preview, work as they should. It’s just in the rendered display mode, and only after using undo.
@DanBayn Hi Dan, I’m looking into this now…however, I’m not able to reproduce it at all here… So can you please…
Export your Rendered mode to a .ini file and post it here.
Save your 3dm file when this happens and post it here as well.
My gut tells me this is some kind of material caching problem that reveals itself when something is undone…but I can’t seem to produce the exact situation/state that causes this.
Also, what is your hardware configuration stats? (OS, Video Card, etc…)
