Hi all,
The material tab is not available when grouped objects (surfaces grouped together with curves) are selected. I seem to remember this wasn’t the case in Rhino for windows. Does anyone have a workaround or know if this will be resolved?
Cheers,
Anthony
you can use shift-cmmd to select individual objects which are in a group…
also, the commands SelPolySrf and SelSrf can be used to select only the objects which generally warrant materials.
so one possible workaround (assuming it’s a complex model which would be too much effort to re-organize everything) is:
• select the group
• _Invert
• _Hide
(only the group is visible now)
• _SelPolySrf
and/or _SelSrf
• edit the materials
• _Show
(brings back the rest of the model)
Thanks, Jeff. Do you know if this will be sorted out in the final version?
no, i don’t know.
i do think we (mac rhino users) should probably expect minimal texturing/rendering capabilities upon first release and i imagine we’ll have to find some work arounds for the foreseeable future… this may or may not be one of those workarounds.
