Material preview noisy
The previews of the material are very noisy. I don’t think that was always the case. But I can’t find the settings for it. What do I have to do?
Advanced settings PreviewSamples. What value do you have now? Try and make it bigger.
Also make sure your gamma is set to 2.2 and enabled for linear workflow.
If you are not happy with the quality of the preview still you can increase the amount of samples. As @maxsoder mentioned: Tools > Options > Advanced, type RhinoCycles.PreviewCycles and increase the sample count from its default 150 to something larger. Try 250, or 500, or even 1000. Note that it’ll make the preview rendering heavier.
I didn’t understand @maxsoder’s answer and was looking in the wrong places. Now I have tried it, unfortunately nothing changes in the preview. I also think that the preview used to be better without me ever changing anything there.
By the way, Rhino does not find anything under RhinoCycles.PreviewCycles. This probably refers to the PreviewSamples mentioned above
The picture shows the setting 1000Samples. With this number of samples it should be much better, shouldn’t it? I am at a loss…
*** Translated with DeepL Translate: The world's most accurate translator (free version) ***
My bad, I indeed typoed and meant to write RhinoCycles.PreviewSamples.
After you have made changes to that setting you should tumble the thumbnail. Click and hold right mouse button and tumble that thumbnail model a bit. Let it render and then check the results.
Still looks like you’re on low gamma settings, you should keep it on and at 2.2.
Thanks for reminding me about the gamma settings. It was only set to 1.
Unfortunately the result is not good. With 1000samples the picture should be much better?
I’m not sure at what resolution this is rendering, @maxsoder is there a maximum resolution that thumbnails are rendered at, then scaled up?
Anyway, I wouldn’t worry too much about the previews. They are previews, not the final product. If the materials render well in Raytraced and Rhino Render then it all should still be good.
I myself typically set PreviewSamples to 10.
Here 10 samples in the materials panel
I’m not worried, I’d like it to be better. Rendering the whole scenes to see it is a bad option. And if you’re satisfied, that doesn’t really help me…
How does the current quality prevent you from reaching your goals?
edit: or ask differently, how would improved material preview help you?
I will log a bug. I might have found a problem. So the floating editor checks for the screen scale, but there is a bug in a few sizes. What does the TestSystemScreenInfo command output? Can you copy/past the information here.
Created https://mcneel.myjetbrains.com/youtrack/issue/RH-85883/Material-preview-noisy-in-floating-editor.
Rhino 8 SR16 2024-12-30 (Rhino 8, 8.16.24365.02001, Git hash:master @ 53a751178efd1a931ad72ff4c6af9d26be01d19b)
License type: Commercial, Build 2024-12-30
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 12-3-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.36
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-3-2024
Driver Version: 32.0.15.6636
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.16.24365.2001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “LeerlaufProzessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.16.24365.2001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.16.24365.2001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.16.24365.2001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.16.24365.2001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.16.24365.2001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Rechner”
@Dietrich_Frank I would like to have the information that the TestSystemScreenInfo command outputs. This will give me more information about the displays you have and how they are setup.
Sorry. Is it correct now?
Screen Information:
Screen 0
IsPrimary: True
Bounds: 0,0,1920,1080
WorkingArea: 0,0,1920,1080
LogicalPixelSize: 1
Scale: 1,3333334
Window Positions (Commands):
Rhino.UI.Internal.TabPanels.Controls.TabProperties:
RestoreBounds: 812,450,296,179
Rhino.UI.Internal.ImportFbxDialog:
RestoreBounds: 707,406,505,267
Rhino.UI.Controls.RhinoColorDialog:
RestoreBounds: 1245,308,636,472
Rhino.UI.Controls.RhinoDialogTableLayout:
RestoreBounds: 810,360,296,333
Commands.Commands.SaveACopy:
RestoreBounds: 756,479,407,122
Rhino.UI.Internal.ImportPdfDialog:
RestoreBounds: 707,431,505,218
Rhino.UI.Internal.ImportSkpDialog:
RestoreBounds: 715,351,489,378
Commands.Commands.QuadrangulateMeshsDlg:
RestoreBounds: 812,453,296,173
Commands.Commands.ExtractMeshFacesByAreaDlg:
RestoreBounds: 724,425,472,230
Rhino.UI.Internal.MeshingUI.MeshSettingsPage:
RestoreBounds: 954,237,613,588
Commands.UI.NewLayoutDialog:
RestoreBounds: 760,380,366,310
Rhino.UI.Internal.TabPanels.Controls.ContainersDialog:
RestoreBounds: 705,290,510,500
Rhino.UI.Forms.PrintInterfaceTable:
RestoreBounds: 560,240,800,600
Rhino.UI.Internal.TabPanels.Controls.WindowLayoutsDialog:
RestoreBounds: 837,290,246,500
Rhino.UI.Forms.DisplayModeOverrideDialog+DisplayUiTable:
RestoreBounds: 792,390,336,300
Commands.Commands.SetCustomLinetype:
RestoreBounds: 677,224,565,632
Rhino.UI.Internal.TabPanels.Controls.ToolBarBrowser:
RestoreBounds: 810,390,300,300
Commands.UI.PluginInfoPanel:
RestoreBounds: 681,190,558,700
Rhino.UI.Internal.TabPanels.Controls.MacroBrowser:
RestoreBounds: 695,220,530,640
Rhino.UI.Internal.TabPanels.Controls.ShouldSaveWindowLayoutMessageBox+SaveAsPanel:
RestoreBounds: 747,473,425,134
Commands.Commands.TabPanels.SaveWindowLayoutCommand:
RestoreBounds: 800,473,400,134
Commands.UI.BlockPropertiesPanel:
RestoreBounds: 805,277,309,525
Commands.UI.InsertPanel:
RestoreBounds: 702,302,516,475
Commands.Commands.ViewCaptureCommand.ViewCapturePanel:
RestoreBounds: 762,230,396,619
Commands.UI.PackageManager:
Rhino.UI.Internal.SetPtDialog:
RestoreBounds: 852,439,216,201
Rhino.UI.ObjectManager.ModalBlockDefinitionPropertiesDlg:
RestoreBounds: 810,340,300,400
Rhino.UI.Internal.ModelBasePointWarningDialog:
RestoreBounds: 473,456,973,167
Commands.Commands.ExtractMeshFacesByEdgeLengthDlg:
RestoreBounds: 750,431,420,217
Commands.Commands.Make2DCommand.Make2DPanel:
RestoreBounds: 812,289,296,502
