Material IDs
I am struggling to find a way how to assign two materials to one object, without exploding it. Simple example, I would like to assign a green material to one side of the cube and pink material to rest 5 sides. But I need to keep it as one object. I migrate it to ue4 and exploded geometry is prolonging render times much. Is this possible at all?
thx
Hello - try: Subobject select (ctrl-shift click) on the face you want to assign green to, and in the Material panel, select your green material, and in the context menu, choose ‘Assign to object’
Any luck?
works like a charm, thank you!
