I’m trying to change the material mapping of some embedded blocks. Is there a way to do this without exploding the blocks?
TIA
H
TIA
H
Hello! Try ‘BlockEdit’.
If it’s a deeply nested block, ‘Insert’ the block you like to change somewhere, then use BlockEdit on it, then delete the block again in the scene ( it’s kept in an internal repository)
Thanks for your reply. I still don’t understand how to use blockedit to change the material mapping within the block. Can you please explain a bit further. See video below.
TIA
H
At 20" into you video you should actually select the object in your viewport too.
Thank you very much!
