I can’t seem to find the detailed settings so I can rotate and adjust the image I’m using as a surface material. How can I rotate an image in the materials tab?
Hello- change the material type to ‘Custom’
Hello- ah, sorry - you cannot rotate the image inside of Rhino materials that I know of but you can rotate the mapping - if you apply planar mapping to the objeect then show the mapping, you can fiddle with the mapping widget.
Hmmm. Where can I find that button? I can’t seem to find it under Properties or the texture panel. And it’s not in my panel options.
above is all the panels it seems I have available to me.
This process is super annoying. Is there any way to copy a UV map I already made from one face to another?
