Hello!
VA 2.13.2.17721
I’ve encountered this bug:
The wall’s material is wrong when the column cuts into it. (Re)moving the column makes the problem disappear.
VA boolean material error.3dm (411.9 KB)
Thanks!
Edit: the problem vanishes also when simply checking the ‘mirrored’ checkbox for the column. Maybe it’s just a broken render mesh of the wall that needed a refresh?
