I am taking over a project for a colleague who setup the file in a worksession. As I have a Mac I have placed the building as a linked block. While working the wall colors, i.e. materials, do not match what is in the block. How can I find what the source of the issue is.?
Hi Jai,
Can you provide your Systeminfo along with a small example of the behavior? Thanks!
System info: Rhino 8 SR16 2025-2-11 (Rhino 8, 8.16.25042.13002, Git hash:master @ d0f731de6fe2c5fdcad78ad80faf154307815f18)
License type: Commercial, build 2025-02-11
License details: Cloud Zoo
Apple macOS Version 15.3.1 (Build 24D70) (Physical RAM: 48GB)
Mac Model Identifier: Mac16,5
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M4 Max
Color LCD (1728 x 1117 @ 120.00Hz)
Smart M70D (3008 x 1692 @ 60.00Hz)
GPU Vendor: Apple
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSafariServices.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/swift/libswiftDataDetection.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.16.25042.13002
example: I have a building built in a separate file. That building has surfaces and or polygons with a material color. In my other file I have brought the building in as a linked block. The materials appear a completely different color.
What appears gray in the linked building block on the wall and Ceiling adjust to Yellow and Blue.
