MatchSurf does not work
I have Rhino 8 and try to match tangency across two surfaces. However, the result is poor and visually the control points across the seam are not aligned on the same line, especial near the bottom. What is the reason?
Sample.3dm (164.2 KB)
This is the file containing the surfaces having this problem.
This is working fine here.. can you post your results or images of the problem you are seeing?
The “Match surface” tool in the latest BETA does not perform well on my side. It must be able to adjust the control points along their matching direction to achieve a better result.
PROPOSAL: Adding a new tickbox with an option called “Adapt ratio” will do the job.
However, it must be mentioned that NURBS surfaces don’t like extreme curvature next to the adjacent edges (too steep change in the direction of the control polygon), this is why it’s essential to keep the control polygon ratio relatively even to minimize the deviation.
Here is a manually adjusted version where I played a bit with the 2nd row of control points of the lower surface to equalize the ratio of the 1st and 2nd row of control points.
I used the new Gumball in Rhino 9 BETA that lets me move the control points along the control polygon.
Sample Bobi.3dm (508.8 KB)
The max G1 obtained after surface matching is 0.689. I’d like to have it below 0.1.
Also, from the picture one can see the two second-to-last control points along the seam on either side and the shared control point don’t lie on the same line. This is unexpected for a G1 match.
Check my post above and also the attached 3dm file. The culprit is the unequal ratio of the distance between the 1st and 2nd row of control points. The 2nd row of control points of the lower surface is far away from the edge, whereas the 2nd row of control points of the upper surface are way too close to the edge. That particular discrepancy causes “the error”.
If you make the ratio relatively equal, the tangency matching will improve a lot.
I achieved a tangency of 0,005 manually just by adjusting vertically the 2nd row of control points on the lower surface (the target surface in this case).
The original surface is coloured in white, the modified version is blue:
Hi Bobi,
Thanks for the insights! I started experimenting per your suggestion. I found that the most effective way is to reduce the curvature on the lower surface. Separately, evening out the length disparity of the control polygons across the seam also resulted in improvement, but not as drastic.
Very interesting learning for me!
